Hello all,<br /> I just purchased a sail boat with a OMC outboard. The previous owner had placed 2- portable steel gas tanks in a locker, below the cockpit (un-vented space). I am going to replace them with a permanent "poly" gas tank<br />and have a couple of questions that someone may be able to answer.<br /> My boat does not have a ground plate, nor a bolted keel. Will the battery negative terminal suffice as a ground/ bond for the installation?<br /> Will the "squeeze bulb" on the gas fuel line work o.k. if I re-locate it close to the motor, outside of the hull at the transom, or can I eleminate it altogether?<br /> Many thanks for any assistance, and all have a HAPPY NEW YEAR. Bill D.
