Jim Robbins
- Jun 15, 2005
- 85
Hi, I have an 1973 Starcraft Aluminum boat, and I want to put in a new 4 position ignition start switch and a radio/CD player. The switch is marked IG , ACC, ST & B and they mean
Ignition , Accessories, Starter(?), Battery(?) (Is this correct?)
Ok, from the radio there is a Black wire labled (Chassis Ground) does this wire go to the - neg. on the battery ?
And a Red wire labled (12V Ignition/Switched), and a Yellow wire labled(+12V Battery/Constant)
and a Orange wire labled Illumination/Dash Light, the Red wire has a 9.5 A fuse and the Yellow wire has a 15A fuse in the wire.
How do I hook-up the radio to the key switch and the battery?
I have the speakers hooked-up correctly. Thank-you
