Installing a tach
GoneFishin'
I want to install a tach on my little 25hp Mercury. It has remote controls installed.<br /><br />I've looked at the wiring diagrams that come with the teleflex tachs. They look more complicated than necessary. Can someone offer to simplify the typical installation for me?<br /><br />Also, my RC has a "D" shaped plug mounted in the front that has 4 male pins in it. What's this for? Could it be for connecting instruments?... Like a TACH???
GoneFishin'
Re: Installing a tach
Thanks MM. The wiring diags & color charts are a big help. But, I am still curious about the teleflex line of tachs. Will they work easily with my little merc? I believe its a 82 model. Serial 6015565.
GoneFishin'
I'm not begging... YET. I know the guys are out there with some ideas. <br /><br />Is the Teleflex line a good one? Is there a better brand?
MercilessMike
Most tachometers are interchangable, there should be a switch on the tach itself to set for number of cylinders or poles on ignition system, To connect tach is normally tach lead, ignition lead and ground. I would suggest to go to teleflex site and see if the model you have is compatible with your outboard.
