installing a tach gauge
raveng60
i hope i can get some advice installing a tach in my boat and get it ready for sumer. <br />the engine it's a '87 force 50hp 2 cycle/cylinder outboard. i'm wondering where should i connect the signal wire to? what about the rest of the wires? thanks
chuckz
Re: installing a tach gauge
The signal input is the gray wire in the harness. It is connected to the AC side of the rectifier at the engine.<br /><br />Ground is to the Negative side of the battery.<br />Power should be supplied from the switched output from the ignition switch.<br /><br />Lighting connected in parallel with the lighting for your other gauges.<br /><br />For that engine you need a tachometer that is designed for Force outboards. Teleflex has the Red International Series tach which will work. It is available here on i-boats.
Realgun
He means a 20 pole tach and in reality that the only 1 that works anymore.<br /><br />Man that was not easy the search function is messed up on the Megamall but here it is Chrylser/force tach. <br />Be happy!
raveng60
yhea i think i allready got a teleflex, later model though. my problem is i need to do some splaicing and daicing with the wires! i got red(ignition), gray(sender), black(gnd.) and blue for the ligth bulb. <br />i got 2 blue coil packs... exactly where should i hook up the sender (gray wire) to it?? i think it would be way easyer that way. any ideas?
