Installing a new/old 130 and have questions about running controls, lines and wiring.
cmb7684
Short sweet and to the point. I had the power head and lower unit replaced on a 130 with the 25" shaft. I'm putting it on a 19' hull that I purchased at auction that originally had a yamaha on it. The motor was stolen off of it and is why it was being sold at auction. The guages and steering system were all stolen some I'm starting over even though I see some cables from the Yamaha still there I would rather change everything over to Honda even if it was interchangable.
So now that it is out of the way of the how and why's what I need to know is controls. I'm looking for a single pull control with forward reverse with built in trim. The center console hull I'm using has a rectangle hole cut in the dash area of the console next to the helm where the control mounts. Is it best to use an electronic control and do they make it for the 130's? Can anyone supply a part number or direct me to where I may look for one?
Guages- I have found several guages packages. I like the 7 guage kit. Does it matter who makes the guages such as teleflex or does it have to be Honda? Do any of you reccomend a guage set for the 130's or suggest I stay away from a particular set?
hydraulic steering- I found a complete kit for 529.00 on ebay that says it will work with the 130. I think it is a bay star made by sea star. Any feedback on this?
Honda wiring Harness. I assume there will be a Harness of some type that will run from the ignition switch to the rear by the motor along with the wires from the guages to the motor and control and hydraulic lines. Is there a Honda wiring harness Kit for the 130 that is universal that connects at the guages and ignition that I should purchase and is it universal where it will work regardless of what type of control or guages I purchase?
I'm new to this so if I have to buy a Honda control specifically please tell me and the same applies to the guages. Also I'm a little confused as to what type of control lever would go into my center console? It does not appear that it would be considered a top mount but it vertainly is not a side mount.
