suzukidave
- Jul 1, 2000
- 387
Hi folks, I need help with the proper installation of those Tempo water separation fuel filters that use the canisters that look like car oil filters. The instructions that came with it are very limited. They say to install the filter on the “suction/vacuum” side of the fuel pump but don’t mention the primer bulb. I installed it on the fuel tank side of the primer bulb, because a long time ago someone posted here that fuel filters should always be on the fuel tank side of the primer bulb (When I moved my old small inline fuel filter in response to that post I got a 200 rpm boost on w-o-t).<br /><br />Here’s the problem. No matter how much I pump the bulb, I can’t get any prime. Before I move the bulb over to the other side, am I doing anything wrong because I don't want the filter to impact performance (should I maybe fill the filter with gas?)<br /><br />I had to lengthen the fuel hose to allow for installation. I am now running about 14 total feet of 5/16" fuel line. motor is a 1990 Suzuki DT55.
