Installed water pump..but
CLICK7
I put a water pump kit and few other o-rings in my 1981 evinrud 90hp replaced the shift rod o ring,cause it was leaking water in lu.Any way every thing works great but when i pulled it out of the water i noticed one spot at the front leaking water between the lower uint and the mid section,since there is no gasket between them ,how does it seal or does this realy matter?
sly36
Re: Installed water pump..but
everything its seal inside the lower unit so no matter ist water exit there
CLICK7
Thanks,sly36,i didnt think it would hurt anything, I just wasnt sure.
