Hi, all
I would like to know how your boat "plumbing" of a bait tank in front of the center console work. I want to install a 20 gal on my 18ft CC seapro to balance the boat out. I can run a input line from the existing pick-up/bait pump at the trans up to and thru the center console, and then "T" the overfolw line to the drain line out. Question - if all pluming are under the deck, Where/How I can run the overflow/drain to? what are my options? Can I put in a drain hole above water line on the side boat? Thank you for your input.
