Inspecting a 1990 70 Horse Mercury
theriver
I'm thinking of buying the above, however, I may not be able to hook a hose onto it and start it up because the weather here is too cold right now. What can I do to protect myself as best as possible. It apparently runs great, but I'd be buying it "as-is". <br /><br />I plan to check the gear case oil, the power trim operation, and do a compression test. Is there much else I can do?<br /><br />Also, I haven't owned one of these particular motors before. Are they OK?
NathanY
Re: Inspecting a 1990 70 Horse Mercury
Check for spark on all cylinders and if possible have a leak down test done on it.. <br /><br />Look at the plugs, see what condition they are in, they will tell you if it is running lean, rich, or hot..
