webster101
- Aug 8, 2005
- 22
ok clams or anyone else who might know,after doing all timing and sych checks.rebulding fuel pump and carbs finally came down to fuel pump volume, looks to me when I take off the hose going to carbs and crank motor with kill switch pulled takes forever to fill one cup of gas?was told by somebody else loss of press working pump from motor but no details they were snowmobile techs but knew all about 2cycle motors claimed they worked the same and something about leaking crank seal or something.took off fuel pump cranked over motor checked pulse from motor it was there but when covering holes with fingers could hardly feel a thing.butted up vacuum hose to hole with fuel press gauge at other end bearly 4psi no spec's on this or other info in factory merc manual.have noticed many other same concerns in past threads could this be a common prob?is this to low of press going to pump?is volume to low?any input or help on methods of diag and/or repair would be of help.motor takes off fine when primer bulb is pumped on accel and have checked everything all lined and antiback flow valves checked for leaks in all lines and tank vents all good this is last possibility.I think im on to something.how about hooking up an electric fuel pump?I have been around for awhile been a car tech for 30 years things have to make sence to me
