inline 6 crank/rod bearing lubrication
monk-monk
how is the bearings lubed in the <bottom end > of a two stroke engine?
Laddies
Banned
Re: inline 6 crank/rod bearing lubrication
The bearings are lubed as the fuel and oil is inducted in the crankcase thru the reed valves
jimmbo
The oil, being thicker and less able to vapourize than gas comes out of suspension and is deposited on the internal parts. Any excess oil that puddles in the crankcase is recirulated by passages and hoses to the crankshaft bearings or blown into the transfer ports
