Information on Johnson Sea Horse?
j0hn
Hi,<br /><br />I have a Johnson Sea Horse 5.5 model CD-11, serial # 1158298. Does anyone know what year this motor is? Also, it is not getting spark at either plug. The points look good, but both coils are cracked. Could this be the reason? Is there anywhere to get parts for this motor?<br /><br />Thanks,<br /><br />John
Tracy Coleman
Re: Information on Johnson Sea Horse?
jOhn<br />1954 Cracked coils are old and probably no good, like the condensers, maybe plug wires, and sparkplugs. If you plan to use and depend on this engine, replace it all. Probably needs a water pump impeller and lower unit oil change and pressure check a carb rebuild with new float. A basic check of the compression to see if it is worth putting $75 in it. If you have tools and want to do the work, get a repair manual<br />Backfire ;)
petryshyn
Napa Auto Parts has the Sierra line of parts. Many parts are available for your model.....
j0hn
Thanks for the information. I don't use the motor, so I just replaced the coils for now. It started up and seems to run well. :) <br /><br />John
