Re: Info requested on transducer mounting
Where in the floor did you lay it? On my boat, there is a ski storage area in the floor that has a small square recesed area, but I'm thinkin' there is 4-6" of fiberglass between this recesed area and the "V" of the boat, so I'm countin' that out. The only other place would be in the "Cubby" area (Under the outboard mounting/swim platform) where the bilge drains, I could mount it on either side of the bilge pump (which cycles "ON" every two mintes to test for water), so I am sort of scared it might throw some kind of interference into the transducer beings it is mounted so close? I have not removed the fuel tank floor cover to see if there are any recese's that might permit the transducer to be mounting in that area. I was hoping someone had the same boat as me and did the "in-hull" mounting thing and could walk me through it (hey, no harm in trying, right?)Thanks......Slyclops
