info on year/model of motor
liz44
I have an Evinrude motor with serial # 251035-e02386. I would like to know the year/ and gas/oil ratio. Tried the ratio that the seller suggested, but billows of smoke came out of engine exhaust. The motor is white with a red stripe . Then the stripe is blue/ next to red. The bottom of motor is blue. Werw told itis 25hp. Any help in determining the proper oil/gas ratio greatly appreciated. The previous owner gave us a ratio of 1 qt. oil to 6 gallons of gas. Seems to run to rich. Could it be another problem?
Joe Reeves
Re: info on year/model of motor
Liz.... You have a 1971 25hp Evinrude. The fuel/oil ratio should be 50/1 (1pt 50/1 oil to 6gal gas).<br /><br />Should you decide to adjust the carburetor for any reason, the proper procedure follows.<br /><br />(Carburetor Adjustment - Single S/S Adjustable Needle Valve)<br /><br />Initial setting is: Slow speed = seat gently, then open 1-1/2 turns.<br /><br />Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.<br /> <br />Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting. <br /><br />When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
