info on sea king
popsmazz1
can anyone give me some info on a sea king 5hp, has a wards model plate wiyh model 15gg0015 searial 385556, I think this a gale made unit, thanks, mike.
popsmazz1
Re: info on sea king
thanks for reply, any other info would be cool, is that a sea king # or wards? if wards can the model be cross referenced? just picked up this motor and I have not tried to start it, I don"t know what it needs yet.
F_R
Honorary Supreme Mariner
15GG-0015 is the Wards model number. Made by Gale Products Division of OMC. The Gale model number is 5S11.
tmcalavy
Sea King was the M. Ward brand made by Gale, a division of OMC. You can use 24:1 fuel mix ratio, point gap is .020, plug gap is .030 on a Champion J6J or J6C plug. Check compression, clean the fuel system (tank, fuel line, carb), and check the lower unit for lube...it takes Lubriplate 105 white engine assembly grease rather than hypoid oil. It shares lots of parts with E-rude/Johnson motors of the same era, early 50's. Very reliable. Don't run it dry, submerge the lower leg in a trashcan or barrel full of water...water should be at least 1/2 to 3/4 up the leg. Running it out of water will fry the water pump impeller real fast. Can you post some pix?
popsmazz1
little guy needs coils and carb work, anyone know who has them? looks just like johnson cd coils except wires are attached.
F_R
Coils are available all over the world, including here at iboats. 18-5181 is the iboats/Sierra Marine part number.
Carb parts are pretty much you are on your own. Fortunatly, they usualy don't need much. Packings are still available from OMC/BRP. If the float is shot, guys have been using the Sierra 18-7208 (Mercury) float by modifying it slightly.
popsmazz1
thanks for the tips, you guys here really help me out.
popsmazz1
hey F R can you tell me how you found that model# cross reference, I looked at discount marine, can"t find it, doesn"t show 5s11, only 5s10, thanks, mike.
F_R
I have all the Gale model numbers in my collection of Gale literature.
popsmazz1
ok I put new coils in it, now I have spark on the top cyl. none on btm. wires check ok, the points look ok, I cleaned them, could it be the condensers?
F_R
Possible, but not likely. They do get leaky and cause weak spark, but to totally kill the spark would be unusual. The easy way to troubleshoot the system requires a multimeter capable of accurately reading resistances of less than one ohm. (The el-cheapo analog ones usually won't) Resistance from the spark plug wire to the coil's ground wire should be several k-ohms. Resistance from where the wire connects to the points to the ground wire should be about an ohm with the points open and zero ohms with the points closed. If you can't get the zero ohm, the points are not making contact....probably your situation.
Lacking all this, take those points apart and individually clean each contact shiny bright, then try it.
popsmazz1
cleaned points, have good spark now, thanks, now I have to takle the carb
popsmazz1
also can you tell me what yr. hp. a sears elgin 571-58501 is, any other info would be cool, thanks.
steelespike
571-58501 is a 46 3.5 hp built by West Bend.My info indicates 3/4pt per gallon.using 30 or 40 wt.With TCW3 you could probably go 1/2 pt per gallon 16:1. Point gap is .020 Champion J11J (J11C) plug set at .050. yes .050.
