Info on an old 5.5 Johnson
lcmarin3
Two questions, help!, Question one, I have an old 5.5 Johnson and I need to find out the exact year, the plate with the ser# & Mod# has fallen off at some time. The serial number I got off of the freeze plug on the side of the block and is J2399963, I believe it is a late 60's or early 70's.<br /><br />Question two, how does the shift linkage disconnect so I can drop the lower unit to replace the impeller. There is no access plate on the side of the housing as with some models. Any help at all would be greatly appreciated, thanks and happy boating.<br /><br />An old salt
alcan
Re: Info on an old 5.5 Johnson
The Johnson CD model 5.5 was made between 1954-1964. Without a model# I can't tell you which year yours is. To disconnect the shift linkage you will need to remove the powerhead. This isn't as much of a chore as it sounds on this model. Once the powerhead this removed everything should be stright forward.
Paul Moir
Sorry, I can't help with the year. You might want to look over old catalogs in the Olde OMC site. <br /><br />All my 5.5 info says you gotta pull the powerhead and disconnect the linkage underneath it. Then you'll have to turn the driveshaft until a pin through it allows the lower unit to drop.<br /><br />Unfortunetly, your going to need a new block->exahaust housing gasket to replace the old one.
