SS MAYFLOAT
- May 17, 2001
- 6,372
Sorry I haven't been on the forum lately, but I'm enjoying all the winter work that I did to my boat and it has been worth the effort. <br /><br />Something that I would like to pass on to new boaters with I/O's is this. Prior to starting your engine please lower your outdrive at least half way. This will prolong the universal joints life a bunch. At my dock which is only about 100 feet from the ramp, only those experienced boaters are aware of this and you can hear those that don't know about this. When your hear loud clicking noise when your outdrive is up all the way, this is the sound of stress. It is only a matter of time and you will be replacing the universals. And by all means "Don't start your engine until it is in the water" just a few seconds is all it takes to melt the impeller. It might keep working, but it won't be pumping enough to do the job.<br /><br />Already have towed 3 newbies in to dock this past June. One was due to water pump failure because he started his engine up before having it in the water. Watched him from my dock and told my son that he was going to have problems later. Which he did. One was due to a siezed outdrive because he didn't check his lube in the outdrive and the other was due to a broken universal. Which he was one of those that liked running his engine with the outdrive up all the way.<br /><br />I hope this tip will help keep you in the water longer and free from problems in the future. Good Luck and remember do not operate your boat if you have been drinking.
