Indentify a part!
Zephead1971
Help me identify this part please so I can order and fix.
Zephead1971
Part Identifying...HELP!!
Need someone to tell me what part this is please.
1987 Chaparral 235XLC
350 260hp V8 Mercruiser
GA_Boater
Please don't start more than one thread on the same issue. Thanks.
Chris1956
You might post in the MerCruiser forum. My guess is that you have an Alpha i Gen II outdrive, and that is the supply nipple for the gear oil reservoir.
GA_Boater
Missed this was in Outboards. Moved.
Bt Doctur
Or the plastic water inlet tube, hard to tell, what you circled
achris
More fish than mountain goat
If it's the water tube you're interested in, then the part number is 32-417621. I'm guessing you found that image in a search, as it's a 4 cylinder Gen II transom assembly, with a late model power steering cylinder. But you since you have a 1987 unit, then it'll be an Alpha One, with a bullhorn exhaust and an early model power steering.. The Alpha One doesn't have an oil reservoir fitting through the transom assembly, so the only thing in that place is the water tube.
Chris........
AShipShow
Yep, definitely can confirm its the water tube.. just changed mine.
