davidsinclair
- Nov 16, 2002
- 3
Good morning all!<br /><br />Yesterday on starting my 1990 115 (oil injected) Yamaha I was greeted with continuous, heavy oil smoke billowing from the exhaust vents just below the cowling. The motor was stopped and re-started five times over a twenty minute period and on the last start, the smoke returned to normal levels. Some wag joked about the fog rolling in as I idled about the harbour like an out-of-control smoke machine.<br /><br />While the smoke was pouring out, the remote oil tank appeared to become pressurised; on removing the cap it overflowed, whereas normally it sits at a lower level. Once the smoke stopped, the pressure in the tank seemed also to decrease.<br /><br />I've checked fuel lines for air leaks and am at a total loss. Do these remote oil tanks use crankcase air to pressurise like some Mariners?<br /> (I've been searching the forums and haven't found anything specific to this problem on a Yamaha). <br /><br />This motor is run weekly and is otherwise extremely reliable. Hoping this is something I can fix myself, and that someone will have an idea where to start.<br /><br />Many thanks in advance. <br /><br />-David
