increase horsepower and speed
have a 25' sea ray with a 225 in it. Is there anything I can do to increase my horsepower and speed in this craft. I read about having a clean hull etc, but is there any modifications I can do to goose up the engine output, like having the head ground, piston change, prop change ( to what pitch )I'm not looking to challenge any hydroplanes, just get it up to about 45. Now I only get about 30. Its a 1973 W/E and so clean it's worth the trouble. Thanks
Franki
Re: increase horsepower and speed
Normally I'd say save yourself the trouble.. outboards are not as easy to "hot up" as other motors..<br /><br />Things you could do that might help.<br /><br />1. Is it proped correctly??? what rpm is it doing at 30mph???<br />2. Maybe boyesen reeds might give you a bit more punch..<br />3. If you are really keen, take your block and heads to a machine shop experianced in porting 2 strokes.. if they are good at what they do, you can get a boost..<br />They could also shave alittle off the heads for more compression, and mess with the jets to utilize it...<br /><br />All of that is gonna be pretty expensive though..<br /><br />number one thing you can do is make sure its propped correctly..<br /><br />If it is propped correctly, then I can't see even all that work getting you the extra 15 mph.<br /><br />Just make sure, that when you are at WOT, that the engine is doing its max rpm's, if it isn't, you are not propped correctly.. <br /><br />Go see a friendly dealer and try some different props with his advice, you might be surprised at the result....<br /><br />rgds<br /><br />Frank
steelespike
D, a 15 mph increase on your boat would take <br />some serious horsepower unless you are getting subpar performance to start off with.<br /> Im assuming its an IO. but we need to know<br />exactly what style boat.Full cruiser, true deep v<br /> hull weight.How much payload etc.<br /> What size prop what rpm at wot.<br />You should check out the motor especially the compression.Would be good to check for wide open throttle and check the timing.
wilkin250r
I've put nitrous oxide kits on small motorcycle engines, I don't see why you can't put one on a boat motor! :D
