In water I/O winterization
Paul Zorko
Any advise out there on the best way to winterize an I/O engine that will reamin in the water over the short winter season we typically have here in northern KY?
mattttt25
Re: In water I/O winterization
stabil in the fuel if it sits more than a month. others can assist with the engine side. good luck-
John Carpenter
If you have shorepower, you can trust your luck...as many do, to a small ceramic heater in the engine room. However if you lose power for any length of time in a cold snap, you may be in trouble. If it were mine, I would run the engine long enough for it to warm up then kill it with oil down the carb...slow at first for about half a quart then dump it down the carb to kill it. Now open all block drains and loosen hoses to drain the engine. After all the water is out...close drains, re-attach hoses, pull thermostat and pour about 3 gal. of pink RV antifreeze down the hole. Spray engine down with corrosion preventative & close it up.
