Re: In The test tank
Did you disconnect the wires?<br /><br />If so, the weak bottom spark is due to some problem up under the flywheel. Usually either dirty points or a cracked ignition coil. The coils in these engines were notorious for cracking and going bad, so if they haven't been replaced in the last 20 years they'll need it. (the new ones are much better) Fortunately, the coils were so common and so bad that replacements are cheap and easily found. Iboats/NAPA auto 18-5181 I like even better than the factory coils.<br /><br />To get a look up under there, you'll need a puller. A common automotive "harmonic balancer puller" (beefiest you can find) equipped with three grade 8 1/4"-20tpi bolts 3 or 4 inches long is required. As well as a torque wrench capable of retorquing the flywheel nut to 105ft/lbs.<br /><br /><br />But the one that is good should fire at least occasionally if you can draw a 1/4" spark. Spark plug wires are the right way round right? Make up some pre-mix (24:1) in a spray bottle and spray it down the carb's throat while cranking the engine. See if it at least coughs on it.
