Re: in-hull transducer removal
This is mounted "in the hull" not "through the hull", right?<br /><br />Most epoxy is pretty brittle. If you hit the transucer sideways (parallel to the mounting surface) with a hammer you will likely break the bond. Hit it from different sides if you can. You can also try using a chisel at the intersection of the transducer and the hull. A chisel will help to remove any epoxy left behind on the hull.
