Hi all. Just thought I’d share some findings from a prop testing run today on a friends boat.
Boat is a regal 1900 fastrac bowrider
Engine mercruiser 4.3 mpi
Alpha 1 1.61 ratio
test run as it was when purchased last year;
Prop 21” 4 blade spitfire all
3 onboard and half tank of fuel
rpm 4950 on limiter
gps speed 47 mph and struggled with trim applied.
Todays result with my Tempest prop
Prop 19” Tempest plus 3 blade
2 onboard and half a tank of fuel
RPM on vessel view 4850
GPS speed 52.5 mph and took so much trim with so much more grip and lift than 4 blade.
Was able to cruise at about 2500 rpm and 20/21 mph. An amazing result and i was really surprised at the result. We were expecting a 21” 3 blade would be perfect for it, given the 4 blade ally was on the limiter and not that quick out the hole. The 4 blade would sit at about 22/23 mph cruise and about 2900 rpm. Just wasn’t expecting the 3 blade tempest of 2” less pitch to drop the rpm all the way through the rpm range and also show less rpm at the top. Suspected it would be quicker, but would also be on the limiter too.
Just wasn’t the case. Just goes to show how varied and different a prop can be on a boat. Threw the rule book right out the window today.
Perhaps further enforced my lack of favour towards a 4 blade prop. In no way whatsoever did the 4 blade show any advantage over a good 3 blade prop. Was incredible how much more lift and trim the tempest managed. Doesn’t get much better. I think the prop slip as a result is down to about 3/4 %. Amazing.
That’s all folks. Hope it helps someone along the way
Alpha 1 1.61 ratio
rpm 4950 on limiter
