impleeler lube
Mack4873
I understand it is important, when replacing the water pump (impeller), to smear a bit of a special lubricant on the blades, and wall of the cavity.
Please tell me what the lubricant is and where to get it.
I've a Honda 15.
Mack
Bob_VT
Re: impleeler lube
Vaseline works fine.... a very light smear on the wall where the impellar sits.
Welcome to iboats!!!
triumphrick
Re: impleeler lube
I agree..but keep in mind, from the time the grease wears off it will continue to be lubed by water. Really important to never let 'em run dry....me...I use a little Yamaha marine grease, the blue stuff.....
