Impellor removal
Tommo
Hello, I am try to replace an Impellor on a 1985 Johnson. I have a problem, I can not remove the actual impellor, the black spline think from the driveshaft. I have tried a lot of things with no luck. Is there a trick to removing the impellor?<br />Thankyou
ob
Re: Impellor removal
I'm visualizing maybe a v-4 Johnson Tommo,but can't be sure unless you specify which engine you have.<br />Assuming so,the impeller is likely froze in place aginst the driveshaft and impeller key which will require a shocking force with a small chisel and hammer on the impeller hub in a rotation direction to dislodge.Some pentetrating oil may also help with this technique.Last resort option is some concentrated heat to the impeller hub.If heat is required ,you'll want to replace the driveshaft seal under the waterpump.
steviecops
Or you could just cut the old impeller off with a hack saw if you're careful.
Dhadley
While you're there, change the pump as a kit, not just the impeller.
OBJ
If you have a dremmel tool with a little cut off blade, that works REAL good at getting them off. Just cut a good slot in it and then take a wide chisel and give it a smack. Pops right apart.
Tommo
Hi thanks for the replies, Its only a 4hp, I got a waterpump kit an so I am replacing everything. Whats a dremmel tool?
OBJ
Tommo....I believe that on the 4 horse, the drive shaft will just pull up and out of the gear case once the impeller housing is removed. Would make it real easy, then, to get the old impeller off.
lark2004
It's a small rotary tool that does everything.....<br /><br /> http://au.dremel.com/HTML/home_fr.html <br /><br />they cost a fair bit here in Australia. <br />The easier option if you don't have one is to cut the old impeller off with a hack-saw. Be careful not to damage the drive shaft.
OBJ
Have you seen the Sears version of the Dremmel, Lark. Nice tool. A little less expensive than the original Dremmel.
lark2004
we don't have Sears in Aus. But there are a few cheaper copies here as well. They are OK, but not as good as the real thing.
OBJ
CRITENEY!!!! NO SEARS IN AUSTRAILIA?????? BLOODY UNCIVILIZED...... :)
glennkil
Nope no Sears, No Walmart, no Home Depot, and worse of all no BASSPRO! ARRRRGHHH!! Everytime I come over to the states I go with one half full case and come back with two stuffed to the hilt.
OBJ
Dang Glenn....talk about underprivleged countries....I really feel for you guys....so much I won't tell you that all the stuff in my tackle shop comes from the same place BassPro get's there stuff......
DHPMARINE
No Walmart ???<br /><br />Not boasting,actually cringing,but I went online with Walmart looking for something.I entered 01420 (my zip code) and there are 10 of them within 50 miles of me.<br /><br />DHP<br />TEN OF THEM !!!!!
noelm
yep, true we do have some of those stores but we are not completley living in a cave, we just have different names like, Bunnings for hardware and Kmart for cheap department store crappy suff, and Supercheap for Auto parts that are sooo cheap, but, they fall to bits a week later, and so on
lark2004
NAPA, we need NAPA. our autostores don't carry any marine parts. And the dealers charge way too much....
