I changed the impellor on my outboard (25hp 2006 2 stroke) today .I put it in a barrel of water it didn't pump anything. I pulled the impellor apart and it look like it ran dry with small flats on the edge of the vanes. I flip the impellor over so flats where on the back end of the vanes and reassembled as before. This time I used water muffs and everything worked fine .I put it back in the barrel of water and it pumped water. My question is it best to prime water pump with muffs when using for the first time after changing impellor. Maybe I spun the shaft the wrong way when assembling water pump and vanes where facing the wrong way? Anyway it pumps plenty of water now and I'm hoping the small flat on vanes won't be a problem.
