How do I change the Impeller on a 1963 Johnson electromatic 75hp. Is it easy or not?
J juice71 Petty Officer 2nd Class Joined Jun 10, 2003 Messages 139 Jun 17, 2003 #1 How do I change the Impeller on a 1963 Johnson electromatic 75hp. Is it easy or not?
C cinder1995 Petty Officer 3rd Class Joined Jun 8, 2003 Messages 89 Jun 18, 2003 #2 Re: Impeller Yes it is rather easy. Disconnect the shifting arm & remove the bolts holding the lower unit on. Once apart you'll see the water pump. The impeller is inside.
K kart33 Petty Officer 3rd Class Joined Apr 23, 2002 Messages 87 Jun 18, 2003 #3 Re: Impeller Step 1 buy a manual<br />step 2 replace the impeller<br />a manual is money well spent especially for an older motor
