impeller
azboater
Ive got a 1988 omc 5.0. Im new to boating and im h earinf a lot about an impeller. What does it do exactly and where can I find it to replace it?
Walter
Re: impeller
What most folks in here mean when they describe the "impeller" is one component of the water pump that is housed in the outdrive. This pump pushes seawater up to your engine's water pump...or to a heat exchanger...depending on what type cooling system you have (fresh water or closed). Your engine's water pump also has an impeller...but again...usually when folks talk about the "impeller"...they are referring to the outdrive's water pump.<br /><br />What model of outdrive is your OMC? Cobra or Stringer (Stinger?...800??) I'm not too familiar with OMC, but I'm sure if you have questions...some one in here can help ya out if they knew what model you have.<br /><br />Walt<br /><br />Walt
azboater
Re: impeller
I have a cobra omc. So does my outdrive have an impeller? and if so how do i get to it?
cbcsr
Re: impeller
Yes you have an impeller. On the rear of your upper gear case is a curved triangular cover with 3 bolts in it. Remove those 3 bolts and you will find the impeller housing that can be removed with 2 or 3 more bolts. Once the housing is off you will see a rubber piece shaped like a donut with fins. That is your impeller.
azboater
Re: impeller
Ok ive got the impeller in my hand. But it seemed like it was wedged in the housing very tight is that normal or is it to big. thanks
scallywag
Re: impeller
no i do not think it is to big,they do rub on the housing.for this reason do not run your outdrive without a water supply.
Stanp
Re: impeller
The impeller is suposed to be tight in there. take it to the parts counter and have them give you an exact relacement. as a quik tip- don't throw the old one out. Keep it on board as an emergency.
