Re: impeller
567890,Your question as to what the two plates were with the four bolts was answered above by Dave.Nothing behind those plates except rubber dampers.Shift rod disconnect is under the lower carb area.Attempting the lower unit service for the first time without a manual as a guide ,will require forum members to write one for you to explain many of the critical points.Many of these guys including myself have already written out the procedure in literally hundreds of other topics.If you'll perform a search on these forums using specific key words,I'm confident that all the info is right here.<br />To simply ask ,"how do I change the impeller?" is a bit like asking,"how do I do my taxes?" Short question,looooooong written answer.Not always, but many times,original poster never replies.<br /><br />There are a few other items you need to consider inspecting/replacing when the lower unit is down for service.Inner exhaust housing rubber seals and water tube grommet ,just to mention a couple.
