Impeller spins clockwise?
pubber
On a 1966 Evinrude If the impellor spins clockwise the ends should be bent towards counterclockwise right? I only noticed the shift shaft and drive shaft sticking up from the lower unit. Is there one sticking out of the top to transport the water? I still have no water to thermostat. You guys are sure knowledge!
D
DJ
Guest
Re: Impeller spins clockwise?
THM,<br /><br />The "tips" of the impeller point the opposite way of driveshaft rotation.<br /><br />There should be a tube hanging down in the exhaust housing, that would be your water tube.
