Impeller replacement
shark45
I have a 1989 mercury 9.9, And I trying to remove the lower unit to replace the impeller. I cannot see where to disconnect the shift rod. I have all three bolts out and the lower unit drops down about an 1 1/2 inches, but no where do I see how or where to disconnect it.<br />Thanks for any and all help.
Peter O
Re: Impeller replacement
If your motor has a plastic plug on the starboard side, have you loosened the bolt (don't remove it) behind the plug while the shifter is in the reverse position? And welcome to the board........
shark45
Peter,Just whent and check to see if it had the plastic plug. There is no plug at all on the housing or the lower unit. I can see almost all the shift shaft, But no where to disconnect it.<br />Thanks for you help.<br />Eric
Peter O
email me and I can send you the service manual instructions or check your local library if you don't have a manual.
