95crownline
- Aug 5, 2001
- 1
I have a 95 Brovo III Mercury outdrive on a 7.4 liter. It started to over heat after about a few hours use. I noticed it when the sound alarm went off. Temp. went up and I shut the boat off, noticed it when boat was at idle. I restarted and put boat on plane and the temp went back to 180 until I dropped the boat off plane. I'm thinking that the impeller went bad. The boat has almost 200 hours. Is the impeller a hard do-it yourself change. Could use any help on this. Thanks for the help- Steve
