Re: impeller replacement
Scott,<br />Let me tell you, I just went thru this whole ordeal and I just don't think these guys who mess with this alot understand (or see it) from our perspective who have never done this before.<br /><br />The screw that holds the shift rod on is VERY hard to get to. The shift rod comes up and slides between 2 prongs that and the screw that goes right thru the middle. In order to get the screw out, I did the following:<br /><br />1) Remove the Air intake box extender (not sure the technical name). <br />2) Remove the shift cable and throtle cable linkage.<br />3) Use a FLEX extension to unscrew the screw that goes thru the level and the actual shift rod. I can't remember the bolt size (3/8 maybe). I could not have done it without a flex extension.<br /><br />Then once you get the screw out, the shift rod will slide right out.<br /><br />Now the hard part is getting the shift rod back into place (line up) with the shifter so you can put that darn screw back in! I used one of those long flex things with 4 prongs that stick out when you push the button on the other end to hold the screw and push it back in once the holes are line up. I had to use a LONG screwdriver to move the shift rod in place, and once in place, push the locking screw in then tighten it up. Hopefully it will be a while before I have to do that again, but it was a learning experience to say the least. My waterpump works great now and glad I saved the $200 it would have cost me otherwise.
