Impeller Replacement 66' Johnson 40hp
J-MAP
I just had my fathers old boat restored. The engine needs a new impeller but I can't figure out how to get at it and I can't seem to find a video or instruction online that shows me how. Something is always different on my engine then the one they are working on. Can anybody help me?
Keep in mind I am very much an amateur when it comes to mechanical work. Everyone I've talked to keeps telling me it's quite easy to do but so far, no luck for me.
Again, it's a 1966 Johnson 40hp Super Sea-Horse.
Electric shift or manual shift?----Step # 1 is to remove the rear / lower cowling.---Disconnect shift rod or wires.-----Then 6 bolts and one big one at the rear.
F_R
Wow, I would have thought you-tube would be crawling with that topic. Not so. At least I couldn't find any.
So, are you looking for a step-by-step? That would take a bit of typing. As mentioned, is it long shaft or short shaft? I assume it is manual shift (Super Sea Horse).
Let us know what you need.
Couple of clicks and I found videos.---Don't forget to search for EVINRUDE on this topic.----Same motor with different color paint.-----Years 62 to 1970 for good videos !!
J-MAP
Do you have a link you could share?
I've searched around and watched a view different videos but their always seems to be something physically different about my engine from they one they are working on. More or less, existent or nonexistent screws and bolts, that sort of thing.
J-MAP
I know, I was kinda surprised as well.
It's a manual shift, and I'm embarrassed to say, I don't know if it's long or short. Sorry, I'm just trying to bring my dads legacy to life, he passed some time ago. We were always on the water, but that was a long time ago and I was never an expert in the mechanical.
I'd probably need step by step but I don't want to waste anyone's time.
When they restored the boat they said they had the engine rebuilt but apparently left in the original impeller, which seems like an oversight. It was fixed up out of town and they did one last test the day before I picked it up. That's when it stopped cycling water. Their mechanic couldn't make it in before I had to leave town with it but they all seemed to think it would be easy for me to do myself.
I'm just wondering if it would be best for me to track down an outboard mechanic, but I'm told they aren't easy to find.
U-tube----Search for 40 Evinrude impeller replacement.----Change wording if need be.----Shows more that 1 video that helps you.----Sorry , links are above my pay grade.
J-MAP
Ha, fair enough, but thanks, I did finally find one that looks like my engine, working my way through it now and so far so good. Strange that it didn't pop up in all my other differently worded searches, but that's the internet for ya.
Thanks for the help.
J-MAP
Thank you, I'm working my way throught it now. I had a fight with one of the screws on the lower cowling that took some negotiating.
airshot
You could also search for a "factory " service manual, they usually give great step by step and pictures !! Makes an excellent accessory if you ever decide to sell !
Crosbyman
when you find an interesting...whatever on the web
  1. go to the top row where the HTTPS:.... bla bla bla is located
  2. at the left most of the HTTPS.... row left click/hold the mouse
  3. Drag across the https al the way to the right to highlight the URL
  4. click the right side of the mouse andthen left click on COPY
  5. the URL will now be store in your paste file
  6. Back of the post you are answering click right on the mouse
  7. go to PASTE
the copied link (URL) will now be transferred to the post and when the readers click on it they will be directed to your article/utube etc..
you will then be paid with appreciation and thanks from fellow boaters. :) takes 3-4 seconds
----Had a fellow on the phone ( 6 hrs away ) couple of weeks ago.----Looking for a used part and asked a bunch of questions.-----I jokingly said---" this should be worth some suds "----Sure enough he brought some when he picked up the part.----You get slammed on here sometimes when you suggest simple trouble shooting steps to take.-----Applause is not needed at all.
