impeller problem
bdarbyups
I have a 1990 Mercury 40 HP 2 cycle and I put in new impeller kit but did not replace the housing. I was wondering what side the copper pipe goes up, the bend to the shaft or away from the shaft? All gasket were replaced and assembled correctly but I get no water stream.
schematic
Re: impeller problem
look in the parts break down. it should show tube.
no serial number = nothing but guesses
bdarbyups
Pipe is on the out side from the shaft, after install impeller working well but I NOW HAVE WATER COMING OUT OF THE THERMOSTAT WIRE CONNECTION NEXT TO #1 SPARK PLUG.
Texasmark
Years ago the copper interconnect tube was un supported and was slightly bent to keep it away from the drive shaft. It went from the top outlet hole of the water pump cover to a hole in the bottom of the engine block. It obviously was sealed at both ends. How depends on the engine. Looking up from with a flash light will allow you to see the hole in the block and the place where the drive shaft inserts. My current '02 90 hp, whose basic design was back in '89 when Merc quit the tower of production and went with 3 cyls, has a bracket to support the tube and it is a piece of cake to line up the hose when inserting the lower unit.
If you have water coming out from around your spark plugs you are getting water from your water pump to your block and your problem is a leaking gasket on the water jacket cover that has holes in it to allow it to fit around the spark plugs. The head in an integral part of the block (as far as I know...most Mercs are that way) so you just have a water jacket cover, not a cover and a head; one gasket not two.
Mark
