Impeller p/n and last minute advice
jajeeper
I am going to drop the lower unit tonight in preparation for replacing the impeller or entire water pump kit, depending on how things look in there. I have done quite a bit of reading on here and have a repair manual. I am praying that the lower unit isn't rusted to the shaft.<br /><br />Can anyone provide me with the Mercury (Quicksilver) part numbers for just the impeller and also for the water pump kit? The guy I talked to at the local merc dealer didn't sound to sure of himself on the phone.<br /><br />Also, any last minute tips for the pros?<br /><br />How much lube will it take to refill the lower unit?<br /><br />Thanks all.
phatmanmike
Re: Impeller p/n and last minute advice
unless you have done it before on this motor, replace the whole kit. this way you know that YOU have done EVERYTHING you could.<br /><br />tips: if you have a digi camera, take pics everytime you take a peice off, so you have a record of which goes where and when.<br /><br />work slowly and patiently. and DONT LOSE THE IMPELLER KEY !!!!!!!!!!<br /><br />www.seatemp.com or www.mercruiserparts.com will have blown ups parts diagrams and parts numbers for you, not to mention be a ton cheeper than the dealer<br /><br />you could really use a manual. not only does it show in detail how to remove the lower unit and replace the pump, but it also tells you how much lube is in that lower unit
KCLOST
The impeller part# is 47-65960<br /><br />Can't find a kit# but here are the parts you need <br /><br />27 - 33146 GASKET, WATER PUMP BASE TO GEAR HOUSING <br />25 - 33145 "O" RING, WATER PUMP BASE <br />46 - 58618A 1 WATER PUMP BASE ASSEMBLY (MERC 850XS) <br />46 - 73802A 1 WATER PUMP BASE ASSEMBLY (MERC 850 LONG) <br />26 - 31489 OIL SEAL, WATER PUMP BASE <br />26 - 55682 OIL SEAL, WATER PUMP BASE <br />17 - 35973 DOWEL PIN, WATER PUMP BASE TO WATER PUMP <br />27 - 32433 GASKET, LOWER - WATER PUMP BASE TO FACE PLATE <br />32435 PLATE, FACE - WATER PUMP BASE TO WATER PUMP BODY <br />27 - 32434 GASKET, UPPER - FACE PLATE TO WATER PUMP BODY <br />46 - 64141A 1 WATER PUMP BODY ASSEMBLY <br />48752 INSERT, WATER PUMP BODY 1 <br />26 - 38970 SEAL, RUBBER - WATER INLET TUBE <br />47 - 65960 IMPELLER, WATER PUMP <br />28 - 56654 KEY, IMPELLER DRIVE <br />10 - 30720 SCREW, WATER PUMP BODY TO GEAR HOUSING (2 1/4") <br />13 - 26992 LOCKWASHER, WATER PUMP BODY SCREW <br />12 - 29245 WASHER, WATER PUMP BODY FASTENING SCREW AND STUD <br />11 - 69069 NUT, WATER PUMP BODY FASTENING STUD <br />12 - 36001 WASHER, WATER PUMP BODY FASTENING STUD <br />11 - 45592 NUT, WATER PUMP BODY FASTENING STUD <br />25 - 30271 RING, RUBBER - CENTRIFUGAL SLINGER (DRIVE SHAFT) <br />23 - 29804 SLEEVE, GUIDE - WATER INLET TUBE <br />37641 SEAL, EXHAUST TUBE
emckelvy
