I have a 2001 bf50a which had a weak tell tale so i decided to replace impeller. With one intake blocked with tape, as i always do when using muffs, i started motor after reassembly and zero water from telltale and smoke from lower unit by shifter after 10 seconds or so, i shut down took it apart and impeller melted! I ordered another but in meantime I reinstalled old one and tried again, no water and light smoke i shut it down quickly. This time old impeller looked ok, not melted like the first. What now should i flush from thermostat to be sure nothing is blocking?
