aggiechris
- Sep 13, 2011
- 5
A few seasons ago, I was doing a routine replacement of the impeller to find that the fins were chewed up. No problem, I replaced the impeller like I had many times before and went to start it up out of the water with the muffs on. After about 20 minutes, the engine started to overheat. I pulled the lower unit down to find that the impeller housing was now melted and the impeller was seized to the shaft. I believed that I had maybe gotten the wrong sized impeller as I do remember it being very difficult to slide the housing over during installation. So I went and got a new housing and impeller and installed, much easier to slide housing over this time. Got to starting again outside of the water with muffs on and again, after about 20 minutes, it starts to overheat. I again pull down the lower unit to inspect and find that the housing has melted once again. I have flushed the system with a water hose and water is moving through the system clearly. I am at a loss at what to do. Any help would be appreciated.
