Anyone have a good source for old chrysler parts? I tried the local NAPA store but they didn't have an impeller for this motor. The Model number is 455HH, serial number 4077. Also, How difficult is replacing the impeller?
Hello bmoore. the impeller you need is 3085. Iboats has them here is the link. impeller <br />I have a chrysler 45 from 1967. Parts are available but you have to look around. Most parts from 55HP and 35HP will work for your motor. Also a good source for cheap parts is ebay. Just search for chrysler outboard
Finally got around to changing out the impeller over thing weekend. Not sure exactly what I have here. The 3085 replacement impeller that I got from Iboat was too large. It was thicker than the one I removed and it was for a larger drive shaft. Is it possible to just replace the whole water pump assembly with a larger pump kit? Any one have any other sources for Impellers? Also, I have a 3085 impeller if anyone needs it.
