Impeller Help
geauxjoe
I have a 94 sea ray sea rayder f14 jet boat with the 90hrsportjet engine in it.Would like to get a little more speed out of her what would be the best impeller to put on it for that just so right performance.The boat will top out now at about 44mph would like to go 50mph +. Thanks geauxjoe
steelespike
Re: Impeller Help
Im sure no expert but impeller wise you are about it. unless it needs a rebuild.<br /> As I understand it Jets run something like<br /> 20 or 30% less than prop driven.
The Marine Doctor
Re: Impeller Help
I will take a stab at this.<br /><br />IF you have a 90hp Engine and it already runs @ the Max RPM's then I would think there is nothing you can do for an impeller to increase the speed.<br /><br />As far as I know the impeller works on the same principle that a prop does...a higher pitch impeller would = a higher pitch prop.<br /><br />You will lose hole shot and possbily top end as the impeller would be harder to turn.<br /><br />Although...I have heard of guys that "Sharpen" their impellers to cut the water better...this generally though gives better hole shot.<br /><br />Hope this kinda helps.<br /><br />TMD
geauxjoe
Re: Impeller Help
Thanks for all the advice that yall gave me. I ordered a manual for it yesterday and I will give sharpening the blades a shot thanks again.
