I have searched this section on the type of water flow from force outboards. I have read two different opinions of the subject. I have a 1983 85hp Chrysler outboard. When I start the outboard and after a couple of minutes, I can put my hand by the two rear leg holes and see/feel moisture and drops of water. After a few more minutes, there are drops of water below these holes on the leg. There is no stream, regardless of rpms. Is this an acceptable condition, or should I get to work? I apologize if this question is not appropriate.
