Benz Mondi
- Aug 30, 2010
- 125
OK as I noted in one of my prior posts, I ran aground slightly and sucked up some sand when I reversed out. This likely was the cause of my over-heat alarm going off, if only temporarily. I figured I might as well do the impeller change in order to make sure that all the sand was gone and it hadn't been changed, per receipt, since 2007 (it's a fresh water only boat that has hit the water only a handful of times during that time period between me and the previous owner). While at it, I went ahead and also changed the fuel pump diaphragm.
Aside from some difficulty in getting the lower unit back into place with all three critical parts alighned: the end of the water tube, the shift rod and especially the upper end of the drive shaft as its splines mate with the power head. I had made sure to mark exactly the position of the shift rod before I started by drawing a ring around it with a Sharpie.
The problem is it now doesn?t fire up. I discovered I still had the shift handle in its Neutral Interlock position (pulled out toward the center of the boat) when I removed the lower unit. Now I can?t push the handle into its Normal Neutral position. I believe that this is why my motor won?t start. I cranks put doesn?t fire up. With the handle forward in the normal Cold Start Position, the starter cranks begrudgingly like it?s still in gear.
How does pulling the handle out for the Neutral Interlock position physically affect the connection of the shift rod at the cap with the cotter pin? Do I have to disconnect the whole lower unit again? Shouldn?t I be able to just take the cotter pin out, remove the cap, push the Shift Lever back into its normal position, pull up or down on the Shift Rod slightly to make sure it?s not in gear, mark the height of the shift rod, re-install the end cap, connect the shift rod and re-install the cotter pin? Afterward, confirming that the gearing works properly by moving the shift lever into a gear, shouldn?t I be able to then start the motor?
Thanks,
AL
Thanks,
AL
