chbailey
- Jul 4, 2007
- 116
Water stream is great. Pump and impeller have never been touched on a 97 'rude 50hp. Someone said that you should change the impeller every 100 hours. I don't have a good idea as to the hours on this motor but I suspect they are fairly low. I have not pulled the housing to check. What is the best way to go about dealing with the impeller?
