I have read many posts regarding equivilant sealant to the M 1000 recomended by Johnson in their older books.
The local shop here says they use Gel Seal II on the crank case halves.
The book also says to put some on the bolt threads when assembling.
Is the Gel seal OK or should I try to find one of the "equivent" products like 3M 847.
What about using it on the bolts as well
The motor is a '70 4Hp and the case is just a flat surface mated together
Thanks
Thanks
