Illuminated Switch troubles...
jasoutside
OK, so I am having trouble with these illuminated switches...
I've actually made the correct connections with my accessories (bilge pump, nav lights) but the illuminated tip of the switch has me stumped.
The lowest one in that photo ^^^ is for my bilge, on/off. It's always lit.
The other two switches are on/off/on. The middle one I have been attempting to get working and like I said, nav lighting is aok. But, switch itself doesn't light at all. I have tried all sorts of stuff but I'll not bore you with the details.
So, simple question...
How do I correctly wire this switch for NAV lights?
(the "red/red/red" is what is stamped on the bottom there, nothing on the top)
Thanks in advance fellas!
Fireman431
Re: Illuminated Switch troubles...
If you are looking to get the switch to light, try a positive wire to terminal C. Most lighted switches require a 12v+ lead to the switch itself.
PS...it is missing a terminal in the center, on the bottom. Here is the proper way to wire a NAV lights switch:
jasoutside
Yah, I had a + lead coming from the fuse block to "C" and the rest wired up like you have in the diagram there. Except, I did try with (and without) a grounded wire from the empty terminal to the ground on the fusee block.
Head scratcher.
Huh, I wouldn't think the missing terminal is the issue. That was actually the setup used from the factory on the switch panel I pulled this off of.
Either that, or the switch light has to be dead. Which, if that were the case, than both of my on/off/on switch lights would be dead then. That seems unlikely too.
Hmmmmm....
:confused:
Thanks for chipping in fireman!
Don S
It could affect how the switch works, with the switch in the off position, using your ohm meter, see if you show continuity between terminals A and B. Then check between D and E.
If they show they are connected, then you can not use it as shown in firemans diagram without installing a diode.
jasoutside
Ok I can give that a shot.
________________________
Random thought but I don't think would make a difference...
These originally came with the push button reset deals but I am now using a fuse block. Here is what I pulled those switches off of...
Diodes, eh?
Dunno, just thinking out loud here.
Edit: Oh man, those clear tubes back there are housing diodes aren't they?
NYBo
Actually, unlike non-lighted ones, lighted switches require a negative battery feed to complete the lighting circuit.
zopperman
Didn't Jas say he tried grounding the switch?
I have a 3 pole switch in my truck that take 12+ in (acc & light) 12- (light) and 12+ out (acc)
NYBo
Yes, but the key is figuring out the correct terminal for the ground. I didn't make that clear.
Precisely!
jasoutside
Well, this morning I tried just about all the combos I could think of (logical and illogical, grounding included) and couldn't get it figured. I can get the nav/anchor light working just fine but the switch light, not so much. Clearly outside of my skill level, or, a bad switch all together I suppose. Either way, I'm done playing with these switches so I'll just be going with something plane jane. Which really, I should have done at the outset.
All good, thanks for your assistance guys. Cheers!
Fireman431
A standard lighted switch requires a 12v- ground to a separate terminal, but the 6 pole switch he posted is missing the 12v+ terminal for the cross over feed.
