ill buy the beer
DJ IAM
Ill buy the beer first timer need help runs fine out of bay but in got nothing already embarrassed so tell me how it is. 25 Yamaha 2 stroke 1986 got open ears I think its a vent issue
jimmbo
Well a run-on sentence makes it difficult to figure out what you are saying. A little punctuation goes a long way. Is it supposed to be?
I'll buy the beer. First TImer needs help. Runs fine out of bay, but in got nothing. Already embarrassed, so tell me how it is. 25 Yamaha 2 stroke 1986. Have open ears, I think it is a vent issue.
Are you saying it runs on muffs or in a tank, but not in the water?
What is the compression? if the tank vent is not open, the primer bulb will likely collapse. Loosen the gas cap to allow air in. Fuel line could be the problem, as could the fuel pump and filter
jimmbo
I don't think the OP knows the thread was moved here
robert graham
Fuel delivery issue...probably a venting problem or weak fuel pump....remove/inspect spark plugs for possible clues to issue....leave the beer off for a while...
robert graham
