I have a 1979 175hp v6 mariner. I have replaced Stator, trigger, both switch boxes, ran the engine in the dark spayed wires, replaced all wires in switch boxes. When I run the boat it is fine until 1800 rpms. Then it misses like cylinders are turning off. When I increase the speed it smooths out and runs right up to 3600rpms where it starts to miss again. Then it runs fine up to WOT. I notice some fouling on #1 and #5 plugs. The carbs have been gone through and cleaned with new needle seat and gaskets. The only thing left that I don't know about is the Idle control box. Could this be the culprit? I disconnected it and taped it off. The boat was smooth up to 3000 rpms. I could not get it go higher it started to bog down. Any Idea's as to what the problem is?
