ignition wiring
mikezfd
I need the color code for the ignition switch fo a 1996 force 90 hp outboart i have a wiring harness with 6 wires
thank you
mike
roscoe
Re: ignition wiring
Welcome to iboats.
What are the wire colors?
Does your engine have cdm ignition.
If not sure, post the serial number.
roscoe
Re: ignition wiring
Than model number doesn't exist.
You must mean 856x7b.
Thats a 1987 85 hp.
Red wire ------------- B terminal
Red/blue wire-------- I terminal
White wire ----------- M terminal
Blue wire ------------- the other M terminal
Green wire ----------- C terminal
Yellow wire ----------- S terminal
The Fireman
Re: ignition wiring
I also need wireing help.
I need to know the wire positions on the ignition switch for a 35 HP Force. Also if you can tell me the year on this motor it would be helpful.
Model 356F91B
Serial No. 021490
PS the control head has a dead man switch
