I have a 06 Trophy Pro 2052. My ignition warning buzzer quit working. It signals when you turn the ignition on before the boat starts and then if there is low oil pressure, high water temp, low drive oil. So, I went to the dealer and got a ne w buzzer. Here is what happened. I removed the old one and installed the new one. Still did not work. There are only 2 wires. I pulled the new one out and tested it directly to to battery. It works. I then got out my multi meter and tested the wires from the boat to the where the buzzer would go. Turn the ignition on and 12v show up on the meter. So I put the buzzer back in making sure polarity is correct. Turn the ingnition on and nothing. I then checke the factory buzzer by connecting it directly to the battery and it does work.
So, 12v does come to where the buzzer is but it wont make it sound. I even went and disconnected the sensor to the drive oil to see if I could trick it into sounding. Does anybody have any suggestions? Any help would be appreciated.
